Heat Transfer. Surface-to-surface radiation node
Posted 03.04.2014, 08:14 GMT-4 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 4.3a 3 Replies
Hello everybody,
I'm a physics student and I'm trying to simulate with COMSOL the heat behavior of a chip connected to a CdTe detector. In my geometry I have domains that are not touching each other and I would like to take into account how they are heating up each other due to radiation. Since they are so close to each other, I think I should use the surface-to -surface radiation node (instead of the surface-to-ambient radiation node), but I do not understand how to use it. The surface-to-surface node does not ask me to give the distance between surfaces. How can I be sure that COMSOL does not only calculate the radiation coming from the surfaces, but also how the surfaces are heated up from receiving the radiation from other surfaces?
It would be helpful if somebody could explain me how to do this.
Thank you in advance,
David
David
3 Replies Last Post 04.04.2014, 04:05 GMT-4
