Error of a water/air microfluidic channel
Posted 13.05.2014, 17:20 MESZ 0 Replies
I am a beginner of COMSOL, I face the problem "Repeated error test failures. May have reached a singularity.
Time : 0 Last time step is not converged."
The simulation is: all the channel walls are hydrophobic. The water flows in from the left to right. And there is a closed air chamber. I want to know how much water pressure will make the water pass through the air chamber. I just want to repeat the simulation the same as
www.ch.comsol.com/paper/drag-reduction-due-to-microbubbles-in-textured-hydrophobic-surface-12515
I run with the "normal size mesh".
Can anyone help me? Thanks!
Hello Kiki Chang
