Thermal Micropump
Posted 09.07.2014, 17:51 MESZ Fluid & Heat, Heat Transfer & Phase Change, Microfluidics, Studies & Solvers, Structural Mechanics Version 4.4 2 Replies
Hi all,
I am trying to build a model of a PDMS micropump that pumps a liquid stored inside its reservoir due to heat. When the air inside it expands due to heat, the liquid will be pumped out.
The heat source is a copper layer attached to the PDMS external walls, with a total power of 0.2 W.
I used heat transfer in solids and solid mechanics modules to simulate this model, but I kept getting an error saying:
"Failed to find a solution. In segregated group 2: The relative error (4) is greater than the relative tolerance. Returned solution is not converged".
- What is the reason behind that?
- Do you suggest using other modules, such as laminar flow or conjugate heat transfer?
Thank you so much
Marwan
Thank you so much
Marwan
2 Replies Last Post 10.07.2014, 19:31 MESZ
