Difference between 1 turn Multi-Turn Coil and Single Turn Coil
Hi all,
will there be any difference if i use Multi-Turn Coil with 1 turn or Single Turn Coil for a power cable conductor (copper)? Ideally there must not be any difference, however, I noticed that they give little different results when i evaluated Resistive Losses (252 W/m for Multi-Turn Coil with 1 turn and 257 W/m for Single Turn Coil). Therefore, Which one should i use?
Akim
3 Replies Last Post 05.08.2014, 07:29 MESZ
Posted: 1 decade ago 04.08.2014, 08:22 MESZ
Hi Akim,
are you working in 2D or 3D?
yes there is a difference. In a single turn coil the current density varies across the cross section whereas the
electric field is constant. For a multiturn coil is is the other way round.
In a DC application the difference in the magnetic field is often zero, but in AC you will see eddy currents in the single-turn coil but not for the multi-turn coil.
I suggest only to use multicoil domains when there are _many_ wires and when skin depth is larger than wire dimensions.
Regards
Jens
Hi Akim, are you working in 2D or 3D? yes there is a difference. In a single turn coil the current density varies across the cross section whereas the electric field is constant. For a multiturn coil is is the other way round. In a DC application the difference in the magnetic field is often zero, but in AC you will see eddy currents in the single-turn coil but not for the multi-turn coil. I suggest only to use multicoil domains when there are _many_ wires and when skin depth is larger than wire dimensions. Regards Jens
Posted: 1 decade ago 04.08.2014, 08:35 MESZ
Thank you for your response, Jens. I am working in 2D. So for solid conductor I should use Single Turn Coil and for stranded one I have to use Multi Turn Coil?
Posted: 1 decade ago 05.08.2014, 07:29 MESZ
Yes, but if the skin depth is smaller than the dimensions of a single strand you should also consider building many single turn coils. Which means extra work, but sometimes the difference matters. Good luck, Jens.
