CFD, wall lift-off and the Boundary Layer attribute
Posted 25.08.2014, 22:45 MESZ Computational Fluid Dynamics (CFD), Mesh Version 4.4 2 Replies
This question comes from my poor understanding of the "boundary layer" tool in the mesher.
1. It appears that these "boundary layers" are one technique to ensure that "wall lift-off" is of the proper order. IS THIS CORRECT? I have worked through this fabulous model www.comsol.eu/model/download/176325/models.cfd.pipe_elbow.pdf and have discovered that they are using boundary layers to get good solution.
2. When I mesh without the boundary layer, I get a certain "appearance" of the mesh, and the minimum element quality is 0.14, which is considered "good." Then I add the boundary layer. This increases the number of elements from about 2.3M to 2.9M, but the minimum element quality now drops to 3E-8 and the mesh does not change in appearance. My interpretation of this is that the boundary layer is a mathematical construct outside the problem at hand, so it does not appear in the mesh, and so this new, lower and "bad" minimum element quality is not a concern. IS THIS CORRECT?
3. I have heard that k-epsilon is degerate near the walls and therefore requires wall functions, whereas the k-omega model does not. Does this mean that wall lift-off is not considered in the k-omega model, and consequently the work with boundary layers is obviated?
Thank you for your kind help!
2 Replies Last Post 19.09.2014, 21:54 MESZ
