Partition Imported Geometry
I'm trying to partition a geometry that I've imported from Solidworks. I've introduced a workplane and drawn a rectangle where I wish to split the geometry to obtain different domains. After this I tried converting the rectangle into the solid, however keep getting an error that says, "output object is empty".
Also can I refine a mesh within a single domain? The purpose behind partitioning the domains is to refine it without any hassle.
Would appreciate any help. I'm kind of new to this.
4 Replies Last Post 27.10.2014, 17:43 MEZ
Posted: 1 decade ago 16.10.2014, 22:27 MESZ
Hello Arjun,
If you can, use 4.4: we've introduced a Boolean Operation called "Partition" that lets you do what you want easily.
Hello Arjun, If you can, use 4.4: we've introduced a Boolean Operation called "Partition" that lets you do what you want easily. Best, Jeff
Posted: 1 decade ago 16.10.2014, 23:17 MESZ
Hi Jeff,
I appreciate your help. Unfortunately I only have access to 4.3b. Any tricks you recommend in this?
Arjun
Hi Jeff, I appreciate your help. Unfortunately I only have access to 4.3b. Any tricks you recommend in this? Regards, Arjun
Posted: 1 decade ago 17.10.2014, 04:13 MESZ
Have you tried combining your geometry with various rectangular blocks (to separate it into the parts you want) using Boolean operations such as difference and intersection?
Posted: 1 decade ago 27.10.2014, 17:43 MEZ
The partition function worked wonders.
I've been going through some literature on the COMSOL website regarding mesh quality. The write up mentions, "minimum mesh quality" as a good parameter to assess mesh quality. It also mentions that these parameters vary with respect to the different applications.
I'm currently working on a 3-D model that simulates microfluidic flow. I'm using an insanely fine mesh yet the minimum mesh quality is of the order e-4. I've ensured the growth-rate is limited to 1 but have the x-direction geometry scale set to 3. (the direction in which steep gradients occur)
Any ideas on which parameters might be a tell-tale sign of a good mesh for a micro-fluidic application?
Cheers
The partition function worked wonders. I've been going through some literature on the COMSOL website regarding mesh quality. The write up mentions, "minimum mesh quality" as a good parameter to assess mesh quality. It also mentions that these parameters vary with respect to the different applications. I'm currently working on a 3-D model that simulates microfluidic flow. I'm using an insanely fine mesh yet the minimum mesh quality is of the order e-4. I've ensured the growth-rate is limited to 1 but have the x-direction geometry scale set to 3. (the direction in which steep gradients occur) Any ideas on which parameters might be a tell-tale sign of a good mesh for a micro-fluidic application? Cheers
