Mikael Noerregaard Nielsen
25.11.2014, 12:06 MEZ
Hi everyone
I'm struggling with a case of heat transfer from hot billet to a cold billet bay. I have started with a simplified model with no convection. The ultimate goal is to analyze thermal stress within different scenarios.
So, I've tried a hole lot of different BC's, but I can't get no convergence.
Any ideas?
The model is rather complex. Have you tried modeling one physics at the time and then adding on? I would start off by only doing the Solid Mechanics, then the Heat Transfer and finally contact analysis. Solver settings is also a way to go as you have both contact analysis and radition, so the model is non-linear - check the knowledge base and/or forum and/or see the following links:
Contact analysis:
www.comsol.com/community/forums/general/thread/34/
Solver settings:
community.cmc.ca/docs/DOC-1453
Your mesh also seems very coarse for contact analysis. See also the Snap Hook model in the Model Library
Best Regards
Mikael
[QUOTE]
Hi everyone
Any ideas?
[/QUOTE]
Contact analysis: http://www.comsol.com/community/forums/general/thread/34/
Solver settings: https://community.cmc.ca/docs/DOC-1453
Best Regards
Mikael
Henrik Sönnerlind
COMSOL Employee
25.11.2014, 21:36 MEZ
Two suggestions:
1. Start by a stationary analysis and use it for the initial conditions of the time dependent analysis.
2. Be careful with setting appropriate scales on the dependent variables, particularly displacement and contact pressure.
Henrik
Two suggestions:
Henrik
