Nodes and element labels
How can I get a mesh wich shows elements and nodes labels?
1 Reply Last Post 12.05.2010, 22:20 MESZ
Posted: 2 decades ago 12.05.2010, 22:20 MESZ
here to I beleive you must use matlab, as normally in COMSOL (this is different from other tools, ps note that) you do not work on the mesh but on the geometry for defining your boundary conditions (BC's).
The mesh is a later "add-on" that gets its properties by inheretance depending on which analysed geometric entity it belongs to.
The node and edge labels, as well as surface/boundaries and subdomain/volume labels are "analysed geoemtry" based.
perhaps one way is to mesh and then save the mesh as a geometry, check the "mesh" menu
Hi here to I beleive you must use matlab, as normally in COMSOL (this is different from other tools, ps note that) you do not work on the mesh but on the geometry for defining your boundary conditions (BC's). The mesh is a later "add-on" that gets its properties by inheretance depending on which analysed geometric entity it belongs to. The node and edge labels, as well as surface/boundaries and subdomain/volume labels are "analysed geoemtry" based. perhaps one way is to mesh and then save the mesh as a geometry, check the "mesh" menu Good luck Ivar
