Optical Transmission Spectra of a Nano Hole Array
Hi All,
I am very new to Comsol and was wondering if it is possible to create a Drude model for a Gold (Au) Material. Also if it is possible to get an optical transmission spectrum for a gold nano hole array?
I've looked at the plasmonic wire grating example as it seems to be the most relevant, but they only have a constant frequency.
Kieffer
1 Reply Last Post 19.01.2015, 07:08 MEZ
Posted: 1 decade ago 19.01.2015, 07:08 MEZ
you can compute s-parameter. The transmission efficiency equal abs(S21)^2 if you have two ports
port 1 is input port and port 2 is out put port.
Best Regards
Ahmed A.Ali
Hi you can compute s-parameter. The transmission efficiency equal abs(S21)^2 if you have two ports port 1 is input port and port 2 is out put port. Best Regards Ahmed A.Ali
