Syngas Combustion in a Round-Jet Burner
Posted 10.02.2015, 00:18 MEZ Heat Transfer & Phase Change, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 1 Reply
I appreciate the help and the terrific model in the COMSOL gallery(Model ID: 14881). I have worked the example and need to make altercations in the problem to fit my modeling need. Everything is very clearly described in the accompanying file (.pdf) except I need a reference for the portion of the model that explains the heat source1, API or where those terms are located in the COMSOL introduction guide?
Under heat source1 is found this input for q:
-(dH_R1*rspf.rEDC_treac1+dH_R2*rspf.rEDC_treac2)
I infer that (rspf) is the model physics reacting flow (rspf) and that the .r is refering to the geometry of the problem (the radial position). I do not know what EDC means; _t means (time for the t). I assume reac1 and reac2 are the two reactions listed under reacting flow.
In my case I have changed the flow to laminar (for which it is in my case in a MEMs burner) and solve a problem with four reactions and have correctly input the dH_1 through dH_4 values (the concentration profile and fluid profile solve seamlessly without the heat transfer physics being added or the heat source 1 included), but do not know how to call the same function for 2D (rectangular geometry without any symmetry, (x,y)).
I tried:
-(dH_R1*rspf.x_yreac1+dH_R2*rspf.x_yreac2...)
Ouch...
Thank you very much for the help, I appreciate your infinitely superior expertise with COMSOL,
Justin
I tried:
Ouch...
Justin
1 Reply Last Post 10.02.2015, 11:06 MEZ
