System of integral equations with parameter not fixed
Posted 04.06.2010, 05:06 GMT-4 3 Replies
Hello everybody,
I use COMSOL for several months but unfortunately the problem I currently can not seem to be solved with COMSOL.
I have to solve a system of integral equations. There are two integral equations (these are two area integrals) and two unknown who are both functions of space (and I call u (x, y , z) and v (x, y, z)). This type of problem is easily solved by using COMSOL mode "General Form" (see attachment) OK ! But my problem is somewhat more complicated because of an additional term which I have not fixed ...
In my equations, so there is this additional term not fixed (I call LAMBDA and is independent of x, y, z) which appears nontrivially in these equations [LAMBDA term appears in the exponential type exp (-LAMBDA ^ 2 * ((x-x ') ^ 2 + (y-y') ^ 2 + (z-z ') ^ 2))].
According to old theoretical results about these equations, the system admits only discrete solutions for u (x, y, z) and v (x, y, z) (I call therefore u_i (x, y, z) and v_i (x, y, z)) and each of these solutions is associated with a value of LAMBDA (I call therefore Lambda_i) and also to be found. This system of integral equations seems somewhat analogous to an eigenvalue equation, but his writing does not appear explicitly as any other writing or elsewhere!
How COMSOL can solve this problem and find all solutions of this system (I mean find all u_i (x, y, z), v_i (x, y, z) and lambda_ i possible) ?
The solver used to solve an eigenvalue problem only works if my problem is written as A*u = LAMBDA * u... this is not the case here. On the other hand the solver "Stationary" only works if there is no term in LAMBDA. The "parametric solver'' is not very useful because LAMBDA not be fixed (even by varying).
Someone does a track to solve this problem with COMSOL? In fact I do not know if this can be treated by FEM...
Thank you for your help ! I am at your disposal for any further information on this model !
Sebastian
Sebastian
3 Replies Last Post 07.06.2010, 05:53 GMT-4
