Convergence problem while simulating a degaussing process
I'm currently running 3-D simulations of ferromagnetic materials that are being degaussed. When I use the "Magnetic Fields" node it works quite well, however, then everything depends on the magnetic flux B, which physically doesn't really make sense.
So I would rather have everything depend on the magnetic field H, which is why I am trying to run my simulations using the "Magnetic Field Formulation" node. Unfortionately, so far it hasn't worked. The problem is, I always get the error message:
Nonlinear solver did not converge.
There was an error message from the linear solver.
The relative error (4e+02) is greater than the relative tolerance.
Time : 4.358435242653585e-07
I have attached the model. Any Ideas what the problem might be?
Thanks in advance,
Rook
2 Replies Last Post 09.09.2015, 10:13 MESZ
Hello Rook Jameson
Posted: 10 years ago 08.09.2015, 10:42 MESZ
Hey Rook
Have you found the reason behind that error??
Regards
Hey Rook Have you found the reason behind that error?? Regards
Posted: 10 years ago 09.09.2015, 10:13 MESZ
Kinda. I guess the reason that it doesn’t work is a flaw in my logic. I was thinking, H is given by the external coils, so I should have a function dependent of H. But what you give Comsol is actually a differential equation, not a function. So now Comsol tries to solve the equation for H, even though H is already given. This causes the problem I guess.
When I use the magnetic field node and let my differential equation solve for B, then it works pretty well.
Regards
Kinda. I guess the reason that it doesn’t work is a flaw in my logic. I was thinking, H is given by the external coils, so I should have a function dependent of H. But what you give Comsol is actually a differential equation, not a function. So now Comsol tries to solve the equation for H, even though H is already given. This causes the problem I guess. When I use the magnetic field node and let my differential equation solve for B, then it works pretty well. Regards
