01.07.2010, 07:36 MESZ
please help me out in its design.....I am not able to make Short circuit and Open circuit between two conductors --by applying a voltage to the electrode/actuator....
09.07.2010, 09:03 MESZ
can any one please upload their .mph file where if voltage applied, there should be some short circuit and open circuit configuration.
Thankyou
Thankyou
17.07.2010, 12:51 MESZ
can any one please upload their already done RF mems switch design?
26.07.2012, 10:57 MESZ
hi i m also solving that same module my project work is Phase shifter based MEMS switch. could you please help me?
05.10.2012, 06:54 MESZ
I am working on RF MEMS switch ( Capacitive switch) . I got a problem while meshing the structure . After computing , I am getting an error.
ERROR : No mesh on domains 4 5 18 19 in geometry 1, mesh case 0.
Even when i mesh all the domains, same error message is displayed . I am pretty new to comsol . I am using 4.2 version.
Is there any particular way of finding a suitable mesh for a particular structure? can we use the same mesh for any type of structure? where can i find some material on meshing ?
05.10.2012, 07:33 MESZ
meshing is almost an art ,), but generally the default physics induced mesh by COMSOL is very good and perfect for a starting point.
What you must ensure is that your last mesh node refers to all "remaining" and not to just a few domains, else you might easily, as you have managed, forget a few domains, and your model is not fully meshed, hence the error
05.10.2012, 09:11 MESZ
Thanks Ivar ,
will you please suggest me how to learn basics of meshing?
Thanks Ivar ,
05.10.2012, 12:57 MESZ
Re-read the doc on the meshing functions, follow the video's on the amin Web site, take a meshing course by COMSOL, come to the conference and take a quick course there, and try it out model after model, it's mainly the exercising gives you the skills, as often ;)
Not to forget try out models exchanged here on the Forum, help us to help each others.
You could also try a search on the FORUM, meshing issues come up quite often
