2 decades ago
30.06.2010, 21:52 MESZ
Ifit's in 3.5 (as I havent checked yet in V4) and you write correctly in COMSOL language with * it shoudl work to replace the viscuasity constant by your formula. If you also use a 2 pase field that is defined by some spatial coorinates you must multiply by some bolean equations()or perhaps the if works too) to tell where to switch from one to the other, no ?
Have fun Comsoling
Have fun Comsoling
2 decades ago
01.07.2010, 00:36 MESZ
thanks Ivar , is there any documnts about how to use 'if' in comsol i am useing 3.5a
thanks again
thanks again
2 decades ago
02.07.2010, 08:51 MESZ
Hello
I beleive it's in the command.pdf, but its just the syntax, else use the boleans i.e. *(x<0) which is =0 false and 1 true (I believe)
Hello
2 decades ago
03.07.2010, 00:22 MESZ
thanks alot ...i will try it
