19.04.2015, 21:43 MESZ
This is interesting because conservation of current will result in an infinite current density in the corners.
Assuming radial symmetry near the corner: Sheet current density K @ radius r
K = I / (π r / 2)
K = σ E
E = I / (π r σ / 2)
The potential V is the negative of the integral of E, so:
|V| = − ln r (2 I/ π σ)
so potential is proportional to the natural logarithm of distance from the corner which is singular at the corners.
So I'm not sure COMSOL can actually solve this problem.
Alternately you can round the corner and apply the current across the entire rounded edge.
K = I / (π r / 2)
K = σ E
E = I / (π r σ / 2)
20.04.2015, 08:17 MESZ
to define a current density you need a volume, area or length ... there is only absolute (total/integrated) flux values issued from a "point", except in COMSOL in 1D because any point represents a default surface (just as in 2D any point represents a default depth/length).
So normally if you define a total current value on a "point" you can at best talk about a max current density in the mesh element(s) that contains the node point, and this flux density will only increase the smaller the mesh element is made => this indeed leads to a singularity.
Personally I avoid to define any flux on any entity smaller than a "Boundary" in the COMSOL sense (see the doc)
I would also suggest that you replace the sharp edge by a fillet of finite length an apply the flux thereon.
Pls do not forget that the COMSOL plots also interpolates the underlying discretized node points, so in sharp corners like this you may get oscillations on the plots that are not truly physical, such as negative concentrations or temperatures ...
Sven Friedel
COMSOL Employee
20.04.2015, 11:34 MESZ
I wopuld add that there is a specialized interface for electric currents in shells. This would be applied to very thin conductors that you would not like to mesh in 3D, e.g. a 3 mm PCB with 50um copper on it.
The default boundary setting would here be on an edge but it would account for the thickness of the layer, so you could still safely apply a current without andy singularities.
Additionally, in electric current interafces you also have point sources
which you can safely use - and which make sense in some technical contexts.
ch.comsol.com/model/a-geoelectrical-forward-problem-9636
Sven
https://ch.comsol.com/model/a-geoelectrical-forward-problem-9636
Sven
