helix3 in Comsol 4 with Matlab
Does anybody know how it is possible to import a helicoidal "helix3" object from Matlab to Comsol 4.0a? This was very easy to do with Comsol 3.5a (create a helix3 object under Matlab and then just import this object in Comsol 3.5a) but with Comsol 4.0a the same method seems no longer possible.
Thanks for any help about that!
Roland
6 Replies Last Post 01.11.2010, 11:11 MEZ
Posted: 2 decades ago 19.07.2010, 16:40 MESZ
I would also be very interested in knowing that. Anyone has any idea?
Magnus Ringh COMSOL Employee
Posted: 2 decades ago 20.07.2010, 08:53 MESZ
The helix commands are not included in version 4.0, which is stated in the Release Notes for version 4.0a. For the upcoming version 4.1, the ability to create helices will be available not only through a command but also as a built-in geometric primitive that you can add to the geometry sequence directly in the COMSOL Desktop environment.
In the meantime, a workaround is to create the helix using 3.5a and then import the geometry into 4.0.
Magnus Ringh
COMSOL AB
Hi, The helix commands are not included in version 4.0, which is stated in the Release Notes for version 4.0a. For the upcoming version 4.1, the ability to create helices will be available not only through a command but also as a built-in geometric primitive that you can add to the geometry sequence directly in the COMSOL Desktop environment. In the meantime, a workaround is to create the helix using 3.5a and then import the geometry into 4.0. Best regards, Magnus Ringh COMSOL AB
Posted: 2 decades ago 20.07.2010, 13:59 MESZ
Thank you for the answer. That's really appreciated.
Posted: 1 decade ago 16.09.2010, 16:53 MESZ
when will 4.1 be released? I need those features approximately yesterday.
Posted: 1 decade ago 16.09.2010, 18:03 MESZ
then if I where you, I would construct it in a CAD tool
Hi then if I where you, I would construct it in a CAD tool -- Good luck Ivar
Posted: 1 decade ago 01.11.2010, 11:11 MEZ
Thanks for the guidance - just tried it in 4.1 and it's a breeze...
