Membrane Deformation without Convergence or Mass Conservation
In the attached file I deform a spherical membrane filled with water with a force applied across a boundary. The applied force appears to cause a deformation that does not converge, but just continues to expand in the direction of the force without stopping. Furthermore, although I have specified the inner fluid to be nearly incompressible, the object appears to constantly increase in volume, suggesting that mass is not conserved. How can I set up this problem such that a deformation at one point on the object causes a complementary deformation elsewhere on the object such that volume is conserved?
1 Reply Last Post 22.04.2015, 08:35 MESZ
Posted: 1 decade ago 22.04.2015, 08:35 MESZ
My colleague Walter has written two very interesting blog posts on the theme of controlling the volume of a cavity:
www.comsol.com/blogs/computing-controlling-volume-cavity
www.comsol.com/blogs/modeling-hydrostatic-pressure-fluid-deformable-container
I think they will contain the information you are looking for.
Henrik
Hi, My colleague Walter has written two very interesting blog posts on the theme of controlling the volume of a cavity: https://www.comsol.com/blogs/computing-controlling-volume-cavity https://www.comsol.com/blogs/modeling-hydrostatic-pressure-fluid-deformable-container I think they will contain the information you are looking for. Regards, Henrik
