different numerical and analytical resistance values
Posted 07.05.2015, 08:48 GMT-4 Low-Frequency Electromagnetics Version 5.0 8 Replies
I have a reallllllly simple problem which I can't figure it out :(
here is the very veryyyyy simple version of my question.
In EC physics, I have a cylinder with constant voltage through it, I have calculated the constant current passing through the terminal and then according to the Ohm' law, I calculate the resistance: R=V/I
then, when I calculate the resitance analytically,
resistance= length/(electrical conductivity*area) , I always get a different value :(
does anyone have any idea , where the problem is ??
Regards
First method:
R=V/I=20/.628=31.8 Ohms
Second method:
R=L/(sigma*A)=L/(sigma*pi*r^2)=10/(.1*pi*1^2)=31.8 Ohms
I can't believe it :)
I got it!!! thanks for great help!!!! :)
Here I come with another problem :)
now I have 3 cylinders, which the size of the middle one is variable.
Cylinder 1: (R=1µm, L=1µm)
Cylinder 2: (r=0.1µm...1µm, l=0.1µm...1µm)
Cylinder 3: (R=1µm, L=1µm)
then with r=l= 0.1µm, the calculated R=V/I is twice the analytical solution (R=L/(sigma*A).
however for r=l=1µm , both solutions give almost the same answer.
do you have any idea where this difference come from??
(bcs of limits on file size, the attached file is not run yet).
Regards
Consider the current spreading out from a hemisphere of radius rs into infinity. You can calculate the resistance as the integral from rs to infinity dr / (2 pi sigma r^2) where sigma is the conductivity. The definite integral is 1 / (2 pi sigma rs). The same is for current flowing into a hemisphere of the same radius.
If I treat the cylindrical cap of radius rc as a hemisphere of the same area, I get:
2 pi rs^2 = pi rc^2 => rs = rc/sqrt(2)
So then the resistance is 1 / [ sqrt(2) pi sigma rc ]
Summing these components into and out of the narrow cylinder I get:
sqrt(2) / [ pi sigma rc ]
so in the limit of the inner cylinder being much narrower than the outer cylinders, and the inner cylinder being of length L, I should get a total resistance of approximately, modeling the end-cap of the cylinders as a hemisphere of the same area, of:
[ sqrt(2) / (pi rc) + lc / (pi rc^2) ] / sigma
Hopefully I did that right....
The key point here is there's a "spreading resistance" term to the total resistance.
In the limit where you had infinitely thin slices of cylinders of radius R1 and R2 such that R1 < R2 the current would never be able to spread to a radius wider than R1 and the total resistance would be equivalent to a cylinder of the same total length with radius R1.
it was very helpful and comprehensive!! :)
I tried the other way, and still I have almost the same value for R (analytical).
so, you guess which values are closer to the real Resistance values?
the one I get from my calculations or the one from the model?
if the results from my model are so far from the reality, what are your suggestions to improve it?
Suggested Content
- BLOG Model Cables and Transmission Lines in COMSOL Multiphysics
- KNOWLEDGE BASE Manually Setting the Scaling of Variables
- FORUM Comparison between numerical solution and Analytical expression - model verification
- FORUM change the numerical values for the physical quantities
- KNOWLEDGE BASE Avoiding Negative Concentrations
