start up crash
I use 4.0 with students license on Windows 7 and have been experiencing the following problem for two days.
I start up the COMSOL desktop but as soon as the outline of the window appears the program crashes. The error log file says:
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x1e632f05, pid=4016, tid=3608
# Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86)
# Problematic frame:
# C [flgraphics_swt_dx9.dll+0x12f05]
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
A week ago it was working fine, therefore I assume it has something to do with a recent Java RE update (also because the MATLAB LiveLink on the other hand works fine). I tried to reinstall older Java RE versions, but didn't help.
Does someone know the fix for this problem?
Thanks!
4 Replies Last Post 30.07.2010, 02:57 GMT-4
Posted: 2 decades ago 18.07.2010, 09:11 GMT-4
Maybe you can try changing the window manager of comsol (settings) to Swing and see if it works?
edit: well, I don't know how you can modify the settings in comsol in Windows without starting comsol. In Mac or Linux there is a startup file called /bin/comsol.
Maybe you can try changing the window manager of comsol (settings) to Swing and see if it works? edit: well, I don't know how you can modify the settings in comsol in Windows without starting comsol. In Mac or Linux there is a startup file called /bin/comsol.
Posted: 2 decades ago 30.07.2010, 00:28 GMT-4
Hi, I also met the same problem with ubuntu and fedora system, could you tell me how to solve it?
Thanks!
Hi, I also met the same problem with ubuntu and fedora system, could you tell me how to solve it? Thanks!
Posted: 2 decades ago 30.07.2010, 01:47 GMT-4
Could you tell me how to change the manager to Swing in linux? Thanks very much.
Posted: 2 decades ago 30.07.2010, 02:57 GMT-4
Look for this text inside the files: graphics.rendering.2drend
I can not tell you exactly, as I don't have currently access to my ubuntu server.
graphics.rendering.2drend=swt
[QUOTE] Could you tell me how to change the manager to Swing in linux? Thanks very much. [/QUOTE] Look for this text inside the files: graphics.rendering.2drend I can not tell you exactly, as I don't have currently access to my ubuntu server. graphics.rendering.2drend=swt
