2 decades ago
19.07.2010, 10:05 GMT-4
I believe the best is to save your modsel as a "m" file and look at the calling sequence therein. There you will find the different names.
One of the issues is that with "one" material only, your Test.mph file should normally refer to "mat1" and not "mat2", but this depends on the "history" of your model file, and I do not know how to do a "reset model" in V4 (it was nice in v3.5a to clean up the model), and after some changes and testsw on the maodel the ".m" file becomes clogged.
Furthermore, I'm not sure it's so easy to have an analytical function call another inside a material definition, as it looks like their names are rather "mat2.def.ana1.Z(...)" and ...ana2... etc. so how is one sure to refer to the right one ? is it def.ana1.Z(...), mat.def.ana1.Z or just Z() ?
Now,in your case you can always reduce the functions to one for "rho" and one for "alpha", no (probably the safest)?
2 decades ago
19.07.2010, 10:19 GMT-4
Wow. That's pretty sexy. I've never tried saving anything as a .m file before. Will take me a little while to flog through that, however :-)
Yes, Ivar, there was a mat1. It was massively complicated (and probably wrong), that's why I deleted it before posting.
The one I posted maybe could be typed into a single line, but it would be quite messy, more generally I do need this functionality.
I think what I am going to do at the moment is get everything working using global functions, and then cut and paste into material and check I get same answer. As you say, it is a question of what syntax.
Magnus Ringh
COMSOL Employee
2 decades ago
20.07.2010, 02:57 GMT-4
Just a comment about the ability to remove old and unused steps from the Model M-file/Model Java-file history. You can do that in version 4 by choosing Reset History from the File menu.
Magnus Ringh
COMSOL
Magnus Ringh
COMSOL
2 decades ago
20.07.2010, 16:43 GMT-4
Magnus Ringh
COMSOL
In my experience with 4.0, reset-history would usually cause a crash or exception to be triggered. I'm looking forward to 4.0a with anticipation that this functionality will be more stable.
Regards, John
[QUOTE]
Magnus Ringh
COMSOL
[/QUOTE]
Regards, John
2 decades ago
21.07.2010, 03:53 GMT-4
Hei Magnus
Thanks for the indication, I found the Reset, and in V4.0a (=4.0.0.982 for me on Vitsa-32) it works fine, and its cleans up the file, without renumbering, thats nice
Have fun Comsoling
Hei Magnus
Have fun Comsoling
2 decades ago
27.07.2010, 23:42 GMT-4
Here is an example of a function calling a function inside a material, (courtesy of COMSOL support) . The syntax is to include the full path, as Ivar had suggested earlier, e.g.
mod1.mat2.def.an2(p,T)
One slight downside is these are "static" references, in that you need to know the model property tag, the material property tag, and so on.
Regards, John
Regards, John
