time variable
Hi everybody,
someone can tell me how to shift the time variable "t" in Comsol 3.5a. In other words, I need to know how it is possible to change, for example, the time variable from <t> to <tau=t-100>. the fact is that I need to solve a final value problem, instead of initial value problem.
Luigi
2 Replies Last Post 30.07.2010, 05:11 GMT-4
Posted: 1 decade ago 29.07.2010, 16:21 GMT-4
I believe too that you an simply inverte the time asw you are saying if you want a final value solution depending on the time. Pls report back it's always useful to hear from such tests
Hi I believe too that you an simply inverte the time asw you are saying if you want a final value solution depending on the time. Pls report back it's always useful to hear from such tests -- Good luck Ivar
Posted: 1 decade ago 30.07.2010, 05:11 GMT-4
Hi Ivar, it's not clear to me what you mean when you write "time asw". Anyway, I'm going to solve the problem in a very simply way. In fact, i think that a final value problem, tipycally involved in case of minimization problems with conjugate gradient method, can be solved like an initial value problem imposing the final value as initial value. At the end of simulation, I only have to change the time variable from "t" to "Tfinal -t" in the report.
Did you mean this way in your reply?
Luigi
Hi Ivar, it's not clear to me what you mean when you write "time asw". Anyway, I'm going to solve the problem in a very simply way. In fact, i think that a final value problem, tipycally involved in case of minimization problems with conjugate gradient method, can be solved like an initial value problem imposing the final value as initial value. At the end of simulation, I only have to change the time variable from "t" to "Tfinal -t" in the report. Did you mean this way in your reply? Thanks Luigi
