comsol 3.5a (version 3.5.0.608) with matlab 7.10.0 (version R2010a) under linux 64bit
Good evening,
when I try to run comsol in matlab mode I get the following message in the matlab window:
??? Undefined function or method 'comsolmexpath' for input arguments of type
'char'.
So I applied the patch following instructions reported in this page:
www.comsol.com/support/updates/comsol35a3/
But patch didn't work. I got these error messages in the console output:
andrea@imxlcpc30:/usr/local/comsol35a$ sudo patch -p1 < /home/andrea/Desktop/comsol_3.5.0.608-p3_linux.patch
patching file bin/comsol
patching file mli/multiphysics/comsol.m
Hunk #1 FAILED at 23.
1 out of 1 hunk FAILED -- saving rejects to file mli/multiphysics/comsol.m.rej
patching file mli/multiphysics/comsolmexpath.m
Hunk #1 FAILED at 8.
1 out of 1 hunk FAILED -- saving rejects to file mli/multiphysics/comsolmexpath.m.rej
patching file mli/multiphysics/initcomsol.m
Hunk #2 FAILED at 32.
Hunk #3 FAILED at 43.
3 out of 3 hunks FAILED -- saving rejects to file mli/multiphysics/initcomsol.m.rej
I did everything with root privilegies.
Does anybody know which could be the problem?
Thanks a lot
Best regards
4 Replies Last Post 06.10.2010, 02:37 GMT-4
Posted: 2 decades ago 09.08.2010, 01:25 GMT-4
Hi, I have the same problem as you. Have you fixxed it?
Posted: 2 decades ago 04.10.2010, 20:29 GMT-4
I executed the command:
patch -Rf -p1 < [download file path]/comsol_3.5.0.608-p3_linux.patch
and I got similar errors. Then I thought maybe that's why the instructions to apply this command had a ">/dev/null" at the end. So, I just disregarded the errors and executed the second command:
patch -p1 < [download file path]/comsol_3.5.0.608-p3_linux.patch
Then I ran comsol and it worked without any errors. It connected to matlab 2010a with no errors as well.
I executed the command: patch -Rf -p1 < [download file path]/comsol_3.5.0.608-p3_linux.patch and I got similar errors. Then I thought maybe that's why the instructions to apply this command had a ">/dev/null" at the end. So, I just disregarded the errors and executed the second command: patch -p1 < [download file path]/comsol_3.5.0.608-p3_linux.patch Then I ran comsol and it worked without any errors. It connected to matlab 2010a with no errors as well.
Posted: 2 decades ago 06.10.2010, 00:21 GMT-4
thank you for updating.
I use comsol on Windows platform.
Is there any patch?
thank you for updating. I use comsol on Windows platform. Is there any patch?
Posted: 2 decades ago 06.10.2010, 02:37 GMT-4
check the main web site, or ask your local rep, that is the best and quickes ;)
Hi check the main web site, or ask your local rep, that is the best and quickes ;) -- Good luck Ivar
