Failed to find consistent initial values
Posted 09.08.2010, 01:48 GMT-4 6 Replies
The setting looks fine and it looks like there is nothing to skip. But I got the following error.
Would you tell me what cause this error usually?
P.S.
This is a transient case and inlet sets as flow-rate and outlet is a zero-traction. The inlet flow-rate is defined used functions based on *.txt.
I am having a similar problem with my model. The difference is that it is a multiphase flow. I am using the level-set method. All the subdomain settings and boundary conditions seem to be fine. I initialize the level-set function as it is recommended in the user guide and use that initial value for the transient solution. I keep getting the same error: " Failed to find consistent initial values. Last time step not converged". Could it be that the inlet pressure is too big? Could it be the solver? the mesh?
Thanks in advance.
The result looks fine and maybe I solved this problem. However I am not sure the procedure.
What I done for this problem is that I set up stationary solver 1 and transient solver1 under study 1 and
right click the study 1 and click show basic configuration for the study 1. And I changed the method from iterative to direct.
And I run and get the result without any error. And the result looks fine.
I think this may be the procedure to setup for initial value for transient solver.
But unitl now I am not sure that this setting make the stationary solver run with the initial value from transient case at t=0.
Is there anyone can confirm this?
Thanks in advance.
So first setup your st.st solver, initial values set to 0. Then your transient solver has the initial values set to solution, and the sol is from the st st solver. You can also have a "store solution" on the st.st solver to keep the results and refer to it later.
I'm heading down the same road, but am stuck on something even simpler. In the attached, I solve first for purely stationary "p0" and then want to use that as the initial value for subsequent transient value "p".
If you look at "Line Graph 1", you can see that the limit solution for large time is correct, but it has picked up some seemingly random function for t=0.
Any suggestions appreciated,
Thanks, John
p.s. Duh. Apparently all it took was me posting here. This is working now. I changed the selections for the initial values in dependent variables 2. Initial values now set to "initial expresion" .... second attached file is the good one.
have you niticed that you have two different pressure values for Pressure 2 in the two Darcy dl1 and dl2. I would expect them to be equal no ?
Suggested Content
- BLOG Using Simulation Software in the Courtroom
- KNOWLEDGE BASE Solving time dependent models with inconsistent initial values
- KNOWLEDGE BASE Improving Convergence of Transient Models
- BLOG Self-Consistent Schrödinger-Poisson Results for a Nanowire Benchmark
- FORUM Failed to find initial consistent values
