Effective index imaginary part doesn't appear.
I am trying to measure the confinement loss in a photonic crystal fiber using the fundamental mode effective index. for a wavelength 1.55um and upwards, the fundamental mode has an inedx of 1.270578-1.825e-10i , which means I could calculate the confinement loss from the imaginary part. But for any smaller wavelength, the effective index of fundamental mode becomes real. It seems like COMSOL isn't calculating imaginary part below e-10i range.
Any solution to this problem ?
5 Replies Last Post 28.03.2016, 14:52 GMT-4
Posted: 1 decade ago 20.07.2015, 07:00 GMT-4
you should always suspect numerical issues if your ratios are > 1E7 or thereabout, as the way numbers are presented by binary coding in the computer limits the resolution to several times the internal variable "eps=2.2E-16" (is FPU dependent).
And as most physics equations are of second order the maximum ratio one should expect is rather several times sqrt(eps)=1.5E-8
Therefore I'm not that astonished that you have issues resolving index ratios in the order of 1E-10 with any numerical binary computing algorithm
Hi you should always suspect numerical issues if your ratios are > 1E7 or thereabout, as the way numbers are presented by binary coding in the computer limits the resolution to several times the internal variable "eps=2.2E-16" (is FPU dependent). And as most physics equations are of second order the maximum ratio one should expect is rather several times sqrt(eps)=1.5E-8 Therefore I'm not that astonished that you have issues resolving index ratios in the order of 1E-10 with any numerical binary computing algorithm -- Good luck Ivar
Posted: 1 decade ago 20.07.2015, 07:16 GMT-4
Thank you. So you are saying this is not an issue with the PML, or giving any imaginary refractive index to the cladding material ?
but confinement loss comes from the equation- Loss= 40*pi*Im[neff]/(loge(10)*L) dB/km. I could only measure losses of order 1e-3 dB/km only if the imag(neff) is of order ie-11. How do you advise to calculate it then ?
Hi Thank you. So you are saying this is not an issue with the PML, or giving any imaginary refractive index to the cladding material ? but confinement loss comes from the equation- Loss= 40*pi*Im[neff]/(loge(10)*L) dB/km. I could only measure losses of order 1e-3 dB/km only if the imag(neff) is of order ie-11. How do you advise to calculate it then ?
Posted: 1 decade ago 20.07.2015, 07:38 GMT-4
I'm "just" saying take care and look very closely to the algorithms when you are having such large differences on derived variables.
Therefore meshing resolutions (discretization of your equations) is even more important when you have such large relative differences.
Unfortunately I'm not experienced enough with the "tricks" to ensure stable numerical values for that particular physics you are using there.
Hi I'm "just" saying take care and look very closely to the algorithms when you are having such large differences on derived variables. Therefore meshing resolutions (discretization of your equations) is even more important when you have such large relative differences. Unfortunately I'm not experienced enough with the "tricks" to ensure stable numerical values for that particular physics you are using there. -- Good luck Ivar
Posted: 10 years ago 01.01.2016, 08:56 GMT-5
Hi, have you solved this problem, I also have this issues, it would be nice to get your advice.
Thanks.
Hi, have you solved this problem, I also have this issues, it would be nice to get your advice. Thanks.
Posted: 9 years ago 28.03.2016, 14:52 GMT-4
Yes, later i found that the imaginary part in fact existed, but it was too small for COMSOL to calculate. anything below 10^-9 doesn't seem to appear in comsol. Change the deciding parameters like wavelength and you'll see the imaginary part starts to appear after a certain increase or decrease of the parameter.
