Magnus Olsson
COMSOL Employee
10 years ago
28.09.2015, 16:12 MESZ
The Floating Potential boundary condition will make the potential constant over the assigned boundaries and the resulting potential will depend on the integral current source, "I0", specified (default: I0=0). The effect is indeed also that the tangential electric field and tangential current density will become zero so for clarity it would be a good idea to state that also in the equation display (besides that the integral current source is I0). The Electric Insulation boundary condition is different as it states that the normal current density is zero locally but the tangential electric field and current density may still be large.
If you read the feature documentation (press F1 when having the Floating Potential feature seleceted), it states that:
"The Floating Potential node is useful when modeling a metallic electrode at floating potential. This is a good approximation when the conductivity of the electrode is many orders of magnitude larger than that of the surrounding medium. "
which tries to give an engineering picture of in what situation to use the feature.
Magnus
Magnus
Magnus Olsson
COMSOL Employee
10 years ago
28.09.2015, 16:31 MESZ
Maybe I should add that in the case of anisotropic conductivity, the floating potential condition will only guarantee that the tangential electric field, "E", is zero, that is:
n x E = n x (-grad(V)) = 0
but as the electric field and the current density, "J", are not parallel, the tangential current density will become non zero.
Magnus
Magnus
10 years ago
28.09.2015, 16:59 MESZ
Thank you! I too believe it would be good to add the "n x E = 0" in the equation description for the boundary condition.
