2 decades ago
16.10.2009, 23:36 MESZ
2 decades ago
30.10.2009, 11:09 MEZ
How do you reinitialize at every time step? Isn't this a process being done only at the very beginning? I am trying to do a two-phase phase field case .. but that doesn't converge either.
2 decades ago
01.11.2009, 09:56 MEZ
I have understood (but I have only followed one training course , hav'nt worked on these solutions extensively) that these kind of problems needs first an "initialisation phase" (short time step) to set up correctly the physics, then you turn on longer time steps analysis.
In your model there is only the initialisation
You can automatise this in the Solver Manager Sequence tab, by first saving a "Transient Initialisation" sequence for a short start up time, save the solution, and then follow by a standard "transient" calculation, but based on the saved values (set up your Solver Parameters correctly for this second phase).
There are a few examples in the doc, and others in the standard models. You need to get aquinted with the solver settings, multiple sequenced solving and the secondary tabs, this takes some training.
It will all be shown in another sequence logic in V4. I'm not sure it will be easier for the new-beginners, but certainly more logical for those of us feeling more familiar with COMSOL and its way to do physics, which is quite different from classical FEM methods limited to a single physics were everything is predefined ready.
2 decades ago
01.11.2009, 16:38 MEZ
Yes, and I have been following these initialization steps closely. I have a uniform grid, and the initialization sesms to work fine - but the simulations simply doesn't converge. And this is a pretty simple 2D-case.
Well, I attach my test-case here. Feel free to have a look - it is a fairly simple two phase inlet-outlet flow with 20% volume fraction gas in. And that's it. Still, it doesn't converge at all ....
2 decades ago
04.11.2009, 15:56 MEZ
I reply to my own post, after having confronted the Comsol-support desk, and I am now instead using bubbly flow, and I am at least one step closer to getting my 3D-case to work. The phase field does not seem to be the right solver for my case anymore ...
