elastic-perfectly plastic diffusion problem
Dear all,
I am simulating the diffusion induced stresses in a sphere. I did the simulation for elastic case (multiphysics structural module with pde) . Now as a next step i see the stresses are high and cause plastic deformation in some portion of sphere during diffusion.
Diffusion is time dependent where as plasticity model(elastic-perfectly plastic ) is static one. When i use time dependent solver it gives an error. How to capture this behavior?
Meena
2 Replies Last Post 25.11.2015, 18:16 MEZ
Posted: 10 years ago 24.11.2015, 18:41 MEZ
Hi Meena,
Both stationary and transient solvers should work for elastic-plastic materials. However, one trick that helps sometimes when you have to solve a static structural problem as a transient one is to exclude inertia effects by setting Structural Transient Behavior to Quasi-static.
Nagi Elabbasi
Veryst Engineering
Hi Meena, Both stationary and transient solvers should work for elastic-plastic materials. However, one trick that helps sometimes when you have to solve a static structural problem as a transient one is to exclude inertia effects by setting Structural Transient Behavior to Quasi-static. Nagi Elabbasi Veryst Engineering
Posted: 10 years ago 25.11.2015, 18:16 MEZ
Thank-you for the help!
system works for istropic hardening model but do not converge for elastic-perfect plastic model .
I set the direct solver setting to nonlinear newton still it fails to converge.
Any suggestion for resolving this issue?
regards,
Meena
Thank-you for the help! system works for istropic hardening model but do not converge for elastic-perfect plastic model . I set the direct solver setting to nonlinear newton still it fails to converge. Any suggestion for resolving this issue? Thanks, regards, Meena
