27.09.2010, 16:59 MESZ
which physics are you using (and which version): truss, beam, solid or home brew ?
Have you checked the degrees of freedom (free , elastic ...) of your system ?
27.09.2010, 17:10 MESZ
I am using solid mechanics in version 4.0a. To help you visualise the model, it is modelled as a thin cylinder (0.405 mm diameter) rolling over a bend radius of 4 mm through an angle of 180 degrees.
What exactly do you mean when you ask about the degrees of freedom? where would i check this? I have tried the following:
Fixing one end and prescribing a velocity to the other.
Applying velocities to both ends.
Applying similar constraints to other parts of the strand for continuity.
Applying physical constraints (Such as a pulley, which the strand then moves through!)
And various combinations of above.
Chris
Chris
28.09.2010, 14:19 MESZ
the DoF for me was : rope = basically one DoF tension (or truss model),
while a solid (if you do not set specifically the anisotropy stiffness tensor) is a bulk "solid" "rod" and not really a "rope"
28.09.2010, 15:03 MESZ
I see what you are saying but the problem is that I want to apply a prescribed velocity, not a load, which you cant do in truss or a beam.
Also surely the model should behave according to its geometry and material properties as opposed to its physics type, no? Just the physics type determines what constraints can be set or am i wrong here?!
Chris
Chris
