Question on conditional statement
Hi All,
Can any one tell me the difference between these conditions:
1. if((x<1.5),k*c,0)
2. flc1hs(1.5-x,1e-8)*k*c
3. flc1hs(1.5-x,1e-20)*k*c
Because,
if i use 1 & 3 conditions then my model is stop converging in the middle of simulation. it is solving some time steps but not all.
if i use 2nd condition then my model is converging and solving complete time steps..
So, i am just confused and unable to think/imagine what went wrong with 1& 3.
I hope some one will come up with comments/ideas/suggestions..
Manohar
2 Replies Last Post 05.10.2010, 01:38 GMT-4
Posted: 2 decades ago 04.10.2010, 04:30 GMT-4
This is a step function. meens exactly at x=1.5 you will have a very sharp change. Solvers hate it.
Means at x=1.5 you have a smoothing of 1e-8 around it. so your value increases from 0 to 1 in a 1e-8 window. It is still very small (unless you work with lasers etc)
This is bad, nearly the same as 1, since 1e-20 is effectively 0. So your increase window is 0, so it is practically a on-off swicth, like 1. Solvers hate it :)
1. if((x
Posted: 1 decade ago 05.10.2010, 01:38 GMT-4
Knowing that "eps" (the smallest number step distinguisable from 1) is 2.22e-16 on my PC, it is really not worth playing with ratios that compare to "eps" even to within a few tousand time.
The binary number system is far from "perfect" and rather different from our decimal representation
Hi Knowing that "eps" (the smallest number step distinguisable from 1) is 2.22e-16 on my PC, it is really not worth playing with ratios that compare to "eps" even to within a few tousand time. The binary number system is far from "perfect" and rather different from our decimal representation -- Good luck Ivar
