Parametric solver does not support parameters in geometry or mesh.
Hello guys,
When I change the size of a geometry with a parameter, parametric don't work as I wish. And there is a warning:Parametric solver does not support parameters in geometry or mesh.
is there anyone who has an idea about this issue?
4 Replies Last Post 16.03.2016, 08:18 GMT-4
Posted: 10 years ago 15.03.2016, 08:55 GMT-4
Use a Parametric Sweep node in your Study branch.
Use a Parametric Sweep node in your Study branch. Best, Jeff
Posted: 10 years ago 15.03.2016, 10:57 GMT-4
Maybe you are using an old version of comsol?
Pu, ZHANG
DTU Fotonik
Maybe you are using an old version of comsol? -- Pu, ZHANG DTU Fotonik
Posted: 10 years ago 15.03.2016, 21:02 GMT-4
yes, I exactly used the parametric sweep. But the size of geometry didn't change, the result wasn't correct.
Thank you so much.
yes, I exactly used the parametric sweep. But the size of geometry didn't change, the result wasn't correct. Thank you so much.
Posted: 10 years ago 16.03.2016, 08:18 GMT-4
Glad I could help.
Glad I could help. Jeff
