about defining Y in reference frame
From the equation ,(in the cavity) V(t0) = -0.01+0.02*Y/5e-2[m]
Is Y the reference coordinate?
Can I define Y if i'd like to limit solving Y at 5e-6[m] instead of time range?
Thank you very much for your help
Pardon for my bad english
1 Reply Last Post 18.01.2011, 12:06 MEZ
Posted: 1 decade ago 18.01.2011, 12:06 MEZ
if you are in 2D or 3D norally y an Y are the 2nd space coordinate (one for the reference frame one for the spatial frame (or the opposite I never get it right pls check carefully, it has its importance. Note also that between 3.5 and 4 there are chnges in the default behaviour (and names) of the frames.
finally in 3.5 take some care with units and fractions, if I remember right 1/x[m] is NOT the same as 1/(x[m]) but pls cross check
Hi if you are in 2D or 3D norally y an Y are the 2nd space coordinate (one for the reference frame one for the spatial frame (or the opposite I never get it right pls check carefully, it has its importance. Note also that between 3.5 and 4 there are chnges in the default behaviour (and names) of the frames. finally in 3.5 take some care with units and fractions, if I remember right 1/x[m] is NOT the same as 1/(x[m]) but pls cross check -- Good luck Ivar
