Non-ideal weak constraints in V4.1
How can I implement the NON-IDEAL type weak constraint for the moving mesh ALE module in COMSOL 4.1? I could find only Bidirectional and User defined for the "prescribed deformation" case??
Many thanks
Tushar
1 Reply Last Post 21.03.2011, 09:25 MEZ
Posted: 1 decade ago 21.03.2011, 09:25 MEZ
the user type allow you to define at will
To better understand, take a "solid" structure apply a Prescribed Displacement boundary condition with values (a,b,c) for (x,y,z), select weak expression,. turn on the equations (preferences) then look at these equations in bidirectional and in unidirectional.
Learn the subtle differences ;), then apply that to your "user defined" ALE boundary conditions
Hi the user type allow you to define at will To better understand, take a "solid" structure apply a Prescribed Displacement boundary condition with values (a,b,c) for (x,y,z), select weak expression,. turn on the equations (preferences) then look at these equations in bidirectional and in unidirectional. Learn the subtle differences ;), then apply that to your "user defined" ALE boundary conditions -- Good luck Ivar
