Microfluidic pipe outlet with free velocity profile?
Posted 08.03.2020, 17:46 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics Version 5.4 0 Replies
Hello everyone,
I am modeling the flow within a microfluidic system, let's just say it is a straight pipe for the purposes of the question. The direction of the flow could be towards either side of the pipe. I set the velocity/pressure at the inlet, and record flow in the outlet. The outlet flow should be fully developed when flow is from the inlet to the outlet (pipe length > entrance length), but it should be completely undeveloped when the flow is from the outlet to the inlet (outlet is the true entrance to pipe). Everything I have tried gives me only a fully developed flow, no regardless of the direction of the flow.
Is there a way to have the outlet flow be either developed/undeveloped depending on the circumstance? I am currently running separate stationary simulations, but eventually I will run a single time-dependent where the flow direction will fluctuate, so ideally the fix would be the same for both flow directions.
Thank you, Christos
Hello Christos Michas
