08.05.2012, 18:18 MESZ
I'm not sure that works, but have you tried to use multiple "definitions View add Hide Entity" and elected the internal boundaries, and then in another node the edges/lines and thereafter the points you want to hide ?
10.05.2012, 14:21 MESZ
I was able to remove most of the boundaries that way, but in extruded circle-domains there are always four "vertical" lines that remain.
Thanks for the help!
Magnus Ringh
COMSOL Employee
11.05.2012, 09:12 MESZ
You should be able to remove the vertical lines by clearing the "Plot data set edges" check box in the plot goup node's settings window. This action, however, also removes all other data set edges from the plot.
Magnus Ringh, COMSOL
22.05.2012, 12:11 MESZ
Hi guys, I believe my question is related and relevant here:
Suppose I want to look at the results of the model I've studied but only in part of the model. So I create a filter telling it what I want to see. I know that if I want to look at a specific domain for example, I can use the filter 'dom==3' or alike. Can this be done with a boundary as well? 'bound==19'? What is the parallel to 'dom' for boundary, or edge?
Shoval
Shoval
22.05.2012, 13:18 MESZ
use rather the Data Set Cut Boundary ot line or ...
Magnus Ringh
COMSOL Employee
22.05.2012, 17:17 MESZ
As mentioned, there are several ways of hiding geometry boundaries that are easier to use than the 'dom' variable. Just for information, the 'dom' geometric variable is valid for all types of geometric entities (even if its name might indicate that it is for domains only). Depending on the context, it represents the domain number, the boundary number, the edge number, or the vertex (point) number. So in a 3D plot group, for example, using a Filter subnode with dom==3 for a surface plot, restricts the plot to boundary 3.
