concrete column
Posted 09.08.2021, 02:56 GMT-4 Structural Mechanics 0 Replies
A concrete column is made. When only solid elastoplasticity is added, the results can be calculated, but when a truss module is added, the following errors appear. A generalized tension is applied to the concrete, and then the prestressed displacement of the truss is connected with the concrete. I don't know if there is any error in this setting, and how to modify the model.
-Geometry: geom1
-Domain: 3
Failed to evaluate variable.
-Variable: comp1.solid.eiel23
-Defined as: comp1.solid.epl23
-Variable: comp1.solid.eel23
-Defined as: comp1.solid.el23-comp1.solid.eiel23
-Variable: comp1.solid.sl23
-Defined as: (2 * Comp1. Solid. D55) * comp1.solid.eel23
-Expression: D ((- Comp1. Solid. Sl11 * test (Comp1. Solid. El11) - 2 * Comp1. Solid. SL12 * test (Comp1. Solid. El12) - 2 * Comp1. Solid. Sl13 * test (Comp1. Solid. El13) - Comp1. Solid. Sl22 * test (Comp1. Solid. El22) - 2 * Comp1. Solid. Sl23 * test (Comp1. Solid. El23) - Comp1. Solid. Sl33 * test (Comp1. Solid. El33)) * (dvol){ test@4 })
Could not evaluate Jacobian matrix of expression.
-Expression: (- Comp1. Solid. Sl11 * test (Comp1. Solid. El11) - 2 * Comp1. Solid. SL12 * test (Comp1. Solid. El12) - 2 * Comp1. Solid. Sl13 * test (Comp1. Solid. El13) - Comp1. Solid. Sl22 * test (Comp1. Solid. El22) - 2 * Comp1. Solid. Sl23 * test (Comp1. Solid. El23) - Comp1. Solid. Sl33 * test (Comp1. Solid. El33)) * (dvol) Thank you for your answer
Hello wey Stephen
