Time sweep + parametric sweep
Posted 27.06.2012, 20:17 MESZ Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers 1 Reply
1. Can I couple the parametric sweep with time dependent solver?
This is what I need: I am applying a set of voltages to a resistor and plotting the joule heating, using parametric sweep. I want to be able to apply these voltages as a function of time, i.e.: in the output plot, as I sweep time from say 1s to 10s, I must be able to see the applied voltage change in steps of, say, 1V every second.
2. Is there a way to apply user defined functions in the parametric sweep?
1 Reply Last Post 27.06.2012, 20:32 MESZ
