                                10.07.2012, 04:59 GMT-4
                                                    Hi Philip,
I have the same problem. I have a non homogen geometry with two materials and I would like figure the equivalent thermal conductivity.
Normally, to calculate the equivalent thermal conductivity we should use the "heat flux". But I don't know how can I use this condition.
Once you have the total flux then you can calculate the conductivity using :
phi=-lambda*S*grad T
Thank you.
                            Hi Philip,
Thank you.
                                Nagi Elabbasi
        Facebook Reality Labs
                                10.07.2012, 11:16 GMT-4
                                                    Hi Philip,
Thermal conductivity is a material property not a property of a whole geometry. I guess you mean the equivalent or effective thermal conductivity had your geometry been made of a uniform material. COMSOL solves the heat equation in each part of the geometry using its own thermal properties. You can then extract the effective properties via post-processing.
Note that for many multi-material systems the effective thermal conductivity will be different in different directions, even though all the constituents have isotropic values.
Nagi Elabbasi
Veryst Engineering
                            Hi Philip,
Nagi Elabbasi
Veryst Engineering
                                18.12.2013, 12:13 GMT-5
I am very new in COMSOL and trying to calculate effective thermal conductivity in 2D but I am not sure how to do this. I know I need to find heat flux but I am not sure if I am doing the process correct. I'd appreciate any help and explain to solve this problem.
Thanks and Regards,
Marziye.
Thanks and Regards,
Marziye.
