Meet problems when computing comsol in the multi-nodes cluster
Posted 16.09.2022, 23:21 GMT-4 HPC & Cloud Computing, Studies & Solvers 0 Replies
Dear.
When I submit a computation task in the multi-nodes cluster with #PBS commands, I find that it took more time to compute with two-nodes than with one-nodes.
Here, one-node contain 16 cores, and when i compute with two-nodes, all 32-cores are used. One-node need 1141s to complete while two-nodes need 1330s.
Could you tell why? Is the problem with my submit script or comsol itself?
Thank you very much!
My #PBS script as follows
#PBS -j oe
#PBS -q "standard"
#PBS -d "/home/xxx/multiphysics/bin/"
#PBS -o "/home/xxx/logs/pbs.out"
#PBS -e "/home/xxx/logs/pbs.err"
#PBS -l nodes=2:ppn=16
#PBS -l walltime=1200:00:00
#PBS -q queue 2
#PBS -S /bin/bash
###############Load environment
module load intel2018
module load anaconda3
module list
##############Get computing resource variables
cd $PBS_O_WORKDIR
NP=cat $PBS_NODEFILE | wc -l
NN=cat $PBS_NODEFILE | sort | uniq | tee /tmp/nodes.$$ | wc -l
cat $PBS_NODEFILE > /tmp/nodefile.$$
###############Execution code
comsol batch -nn 2 -nnhost 1 -np 16 -inputfile /home/xxx/test.mph -outputfile /home/xxx/test-solved.mph -batchlog /home/xxx/test.mph.log
############## Clean up temporary files
rm -rf /tmp/nodefile.$$
Hello XH L
