Acoustic absorption coefficient
Hi community,
I want to calculate acoustice absorption for porous strucuture, that too without using the JCA or any emperical / semi empirical models.
Is it possible to use Thermoviscous acoustic model to do the same?
Please share your valulable suggestions.
Advance Thanks
Regrads Nagendra
2 Replies Last Post 16.04.2023, 15:08 GMT-4
Mark Cops COMSOL Employee
Posted: 3 years ago 15.04.2023, 22:28 GMT-4
Hi Nagendra, If the absorption from your porous structure is due to thermoviscous boundary layer effects, then yes this can be modeled with the Thermoviscous Acoustics interface. This is a good assumption in the limit of rigid framed porous materials. This would require a detailed mesh of the porous material. You may also find the following reference helpful: https://asa.scitation.org/doi/abs/10.1121/10.0001959 .
Posted: 3 years ago 16.04.2023, 15:08 GMT-4
Thank you so much.
It looks intresting will work on it.
Thanks once again
Thank you so much. It looks intresting will work on it. Thanks once again
