20.10.2012, 12:34 MESZ
i beleive you must tell us which physics you are using, if it's solid heat exchange (only He conduction) or with fluid flow (mass and heat transport). Because for me an inlet in a physics solid case isnt really inline with my understanding ;)
Nagi Elabbasi
Facebook Reality Labs
21.10.2012, 02:18 MESZ
One way to model the gas volume is to create a block to represent that volume and subtract from it the heat exchanger geometry. You should not model that space as a “solid”. There is heat transfer in fluids capability which, as Ivar described, can handle convection as well as conduction through the gas.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
22.10.2012, 17:57 MESZ
Hello Ivar,
I'm using turbulent flow, fluid heat exchange and solid heat exchange models. In some operating conditions it is sub-atmospheric, so i have to use the transitional rarefied flow model.
Geoff
Hello Ivar,
Geoff
[QUOTE]
[/QUOTE]
22.10.2012, 18:15 MESZ
Good Morning Nagi,
Yes, I think I will need to use some kind of subtraction function to define the space. I realize that is it will not be a solid, but a 3D space filled with gas, but I think Solidworks thinks everything is a solid (hence the name!). The void to be filled is made more difficult because of internal turbulence inducers, I'll let you know how it goes.
Thank you for the help,
Geoff
Nagi Elabbasi
Veryst Engineering
Good Morning Nagi,
Geoff
[QUOTE]
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
Jeff Hiller
COMSOL Employee
22.10.2012, 18:47 MESZ
The CAD Import Module provides an automated capability to turn the inside of a hollow object into an object of its own: the "Cap Faces" capability. This feature was introduced at version 4.2: see
www.comsol.com/products/4.2/ and look for "Cap Faces".
The CAD Import Module provides an automated capability to turn the inside of a hollow object into an object of its own: the "Cap Faces" capability. This feature was introduced at version 4.2: see http://www.comsol.com/products/4.2/ and look for "Cap Faces".
22.10.2012, 21:30 MESZ
Thank You, Jean-Francois
I'll give that a try, that's exactly how I hope the program would work!
Geoff
Geoff
