Double parametric sweep
Posted 30.10.2012, 06:49 GMT-4 Computational Fluid Dynamics (CFD), Studies & Solvers Version 4.3a 0 Replies
I faced a problem with two parameters sweep. I simulate a gas flow with transport of diluted species, so there two parameters: inlet gas velocity and diffusion coefficient. I have two physics and two studies. In study 1 which deals with laminar flow I have a study continuation for inlet velocity. The problem is in study2 where diffusion coefficient changes. I tried two make two rows in study continuation or to choose "ALL" in parameters values in the folder "Variables not solved for" but any time only last value of inlet velocity is used. I checked it by some surface integrations. When parametric sweep is added also only last value of parameter is available.
How can I fix this problem to make a nice 2d sweep. Is it somehow possible to get a lot of solution for flow and after that for each of them try a number of diffusion coefficients?
Thank you for helping,
Evgeny
Hello Evgeny Mogilevskiy
