Doubt about transitorial analysis
Greetings!
I have a doubt about transitorial analysis. Let me explain: I´ve been looking for tutorials about the subject and I found one of CFD concerning a cylinder, I leave the link so you can check it:
www.comsol.com/showroom/downloadfile/model/97/version/comsol42a/file/models.mph.cylinder_flow.pdf
In this toturial a Step function is declared and is used to vary the average speed from 0 (zero) to U_mean.
My question is: Why is the funtion Step_1 used in the argument t[1/s]? According to me, we could use t[s] to obtain a "linear variation", even t would be valid as an argument to the function Step_1.
The point is, I have done this changes and the program is marking me errors.
3 Replies Last Post 07.11.2012, 19:07 MEZ
Posted: 1 decade ago 06.11.2012, 06:37 MEZ
the reason for the t[1/s] is to make "t" witout units as most functions expect unitless values,
"t" has by default a unit of "s" so t[s] means s^2 type units
if you wtite t[1/min] t would count in minutes, that is 1,2,3 would correspond to minutes, while t[1/h] in hours etc
Hello, the reason for the t[1/s] is to make "t" witout units as most functions expect unitless values, "t" has by default a unit of "s" so t[s] means s^2 type units if you wtite t[1/min] t would count in minutes, that is 1,2,3 would correspond to minutes, while t[1/h] in hours etc -- Good luck Ivar
Posted: 1 decade ago 07.11.2012, 18:50 MEZ
Thank you very much.
Greetings from México
Thank you very much. Greetings from México
Posted: 1 decade ago 07.11.2012, 19:07 MEZ
Hola
Youre welcome
From Switzerland, here ;)
Hola Youre welcome From Switzerland, here ;) -- Good luck Ivar
