23.11.2012, 15:43 MEZ
indeed that is quite some RAM, but depending on how many DoF you have it might not be enough. Have you checked what kind of RAM you need ? there is a KB knowledge base document discussing DoFs and approx RAM and mesh types
23.11.2012, 16:50 MEZ
I am impressed by your immediate response. Thank you very much.
My structure is 3D and has 663000 elements.
I have 7 different dielectric layers which have same length and width but very different height. For exaample three of them are X nm , 3 of them 4*X nm and 1 layer of 30*X nm. It is obvious that there is a big ratio between the height that is why I use finer and extra fine mesh, otherwise I have some instabilities in the solver. I have used swept meshing for each boundary-domain. Furthermore, the whole structure is excited by two lumped ports from 1Ghz to 10Ghz
I suppose that I will find this knowledge base in manual. If I am wrong please tell me where to find it.
Thank you again.
Thank you again.
23.11.2012, 19:41 MEZ
if I replied rapidly it was just fair luck, I was waiting 30 sec for Comsol to finsih a solver sequence, so I took a visit to the Forum ;)
Now 600kDoF is not that much, why should that give RAM issues when you have so much ?
OK if you have fine layers the meshing is tricky, and at high RF frequencies you need to have also many elements per wavelength * index of refraction.
Have you considered if it's possible to transform some of the thin layers in "surface physics" ? sometimes this helps, else you would need N elements in the thickness, at least enough to solve your depedent variables, and their slopes
29.11.2012, 18:54 MEZ
Thank you very much for your response. The problem was that I had a lot of elements in swept distributiion. So this problem has been solved. I would like to ask you another question if it is possible. I would like to calculate the impedance of this multilayer, what would be the appropriate boundary conditions?
Thanks in advance.
Thanks in advance.
30.11.2012, 08:03 MEZ
for quick impedance calculations, you should study the lumped port / terminal BCs in the doc and compare these to the electric potential or electric current BC (which are for field variables BC values, and not scalars)
