High-Velocity Single Particle Impact and Shear instability
Posted 10.03.2026, 11:58 GMT-4 Structural Mechanics, Structural Dynamics Version 6.4 1 Reply
Hi everyone, I'm currently working on a high‑velocity impact simulation using the Solid Mechanics interface with the Johnson–Cook plasticity model. I keep running into repeated failures in the elastoplastic update.
Here is a summary of the situation:
Material model: Johnson–Cook A = 90 MPa B = 292 MPa n = 0.31 C = 0.025 m = 1.09
Mesh: ~0.25 µm element size (≈ d/100 for a 25 µm particle) Loading: the particle starts with an initial velocity and travels across a small gap before contacting the substrate Time stepping: explicit, Δt ≈ 3×10⁻14 Local method: Backward Euler (Damped) Mass matrix: lumped Explicit time stepping - Verlet Method with Adams-Bashforth 2 Auxiliary solver. Steps taken by solver: Manual - ts.
