Piezoelectric Power Output Visualization
This is probably a simple question but what the heh.
Lets say I have a simple energy harvester beam model fixed at one side and supplied with a body load at the other.
This body load is simply pzd.rho * acceleration
Now eventually I would like to create a simple video of the harvesters discplacement and power output response for a sepcific frequency (600Hz) overa time period. So I can show the 3D model wobbling about (techincal term) and similarily show what I imagine is a sinusoidal type 2D plot of power output.
What particualr study type should I use, something like Time-dependent analysis, is such a thing mentioned above feasible? I beleive it is but thought I would ask first.
MF
2 Replies Last Post 19.03.2014, 22:58 MEZ
Posted: 1 decade ago 19.03.2014, 22:54 MEZ
Hi Michael,
yes you can produce animations of the device. If the applied load is harmonic you would use a frequency domain study, if it is non-harmonic you have to use a time dependent study.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Michael, yes you can produce animations of the device. If the applied load is harmonic you would use a frequency domain study, if it is non-harmonic you have to use a time dependent study. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 19.03.2014, 22:58 MEZ
Well the applied load is simply acceleration which is: 0.1[m/s^2]
This was the best I could disect from a previous thread on a beam shaker to try and emulate a source of vibration at a specific frequency anywhere between 200Hz to 700Hz would have been fine.
I have now idea whetehr it is harmonic though.
Kind Regards
MF
Well the applied load is simply acceleration which is: 0.1[m/s^2] This was the best I could disect from a previous thread on a beam shaker to try and emulate a source of vibration at a specific frequency anywhere between 200Hz to 700Hz would have been fine. I have now idea whetehr it is harmonic though. Kind Regards MF
