bug: blocks changing names
I have a problem using COMSOL (heat transfer module): every time I close my mph files, when I reopen them, all the names of the blocks change, switching between them.
I think the names are assigned according to a predetermined order, since the wrong names don’t change if I don’t try to correct them.
I have thought that could depend by the fact that I worked starting with models created with previous versions of COMSOL, but now this bug happens always, also when I create the model starting from the beginning, also with very simple models, made of just two or three blocks.
I hope you can help me to fix this problem, if you need some other information, ask me.
4 Replies Last Post 16.06.2010, 11:57 GMT-4
Posted: 2 decades ago 16.06.2010, 01:28 GMT-4
I have no way to nkow what's happening inside COMSOL I'm not by Comsol just a convinced user that this is a beautiful tool).
I can only say
a) check that you have the latest version/patch (especially for V4)
b) restart your model from scratch, new (without opening it from a previous version)
c) if still there report back to "Support" with your example and some explanations so they can have a closer look
Hope this hleps
Hi I have no way to nkow what's happening inside COMSOL I'm not by Comsol just a convinced user that this is a beautiful tool). I can only say a) check that you have the latest version/patch (especially for V4) b) restart your model from scratch, new (without opening it from a previous version) c) if still there report back to "Support" with your example and some explanations so they can have a closer look Hope this hleps Ivar
Posted: 2 decades ago 16.06.2010, 04:31 GMT-4
Thank you for the help.
But the problem is not only on a file, is a problem of all my files, even if I restart, I have the same problems.
Even with simple models with three blocks i see them changing the names.
Thank you for the help. But the problem is not only on a file, is a problem of all my files, even if I restart, I have the same problems. Even with simple models with three blocks i see them changing the names.
Posted: 2 decades ago 16.06.2010, 09:17 GMT-4
for me you must have trouble with your installation, as its rather rapid, try again, do not forget to use the update-patches from the support page above
I have not observed anything like that
Hi for me you must have trouble with your installation, as its rather rapid, try again, do not forget to use the update-patches from the support page above I have not observed anything like that Good luck Ivar
Posted: 2 decades ago 16.06.2010, 11:57 GMT-4
I know that sometimes can happen with files created with oldest version of the version used... but the strange thing here it`s that happens with every file, also created by me with my version of the program.
