Can I export a file of mutiphysics to COMSOL script or MATLAB code?
I modeled a structure, for example, with height 300nm.
I wanna simulation this feature with height from 100nm to 500nm and plot the result versus height.
To do this, I think I have to export this feature to code and using loops..
Are there any method to do this?
Thanks for all your helps.
2 Replies Last Post 10.08.2010, 02:12 GMT-4
Posted: 2 decades ago 10.08.2010, 01:48 GMT-4
hi
first, you can open comsol with matlab, and then push ctrl+f
hi first, you can open comsol with matlab, and then push ctrl+f
Posted: 2 decades ago 10.08.2010, 02:12 GMT-4
If you are using Comsol 4, you can easily use parametric sweep feature to do this. Your hight will be the parameter and you can either have a probe to check your desired variable in time, or post-processes later.
In comsol 3.5, you need to access matlab. It is very well documented in the manual. Just search for matlab.
[QUOTE] I modeled a structure, for example, with height 300nm. I wanna simulation this feature with height from 100nm to 500nm and plot the result versus height. To do this, I think I have to export this feature to code and using loops.. Are there any method to do this? Thanks for all your helps. [/QUOTE] If you are using Comsol 4, you can easily use parametric sweep feature to do this. Your hight will be the parameter and you can either have a probe to check your desired variable in time, or post-processes later. In comsol 3.5, you need to access matlab. It is very well documented in the manual. Just search for matlab.
