Iterations
Posted 20.08.2010, 10:50 MESZ 0 Replies
My problem is a little bit hard to describe, but here goes.
I have an L-shaped channel (I have attached it) with the inlets being the boundaries on the bottom. I am describing an inlet velocity field of u(x) = k [IOP - P(x)], where IOP = 2000 Pa (roughly). I usually start with an initial guess of P(x) = 1200 (call this P1(x)) for example, and then I solve. After I have solved, I take the pressure field along the inlet, and use the interpolation function to create a new P(x) - this one is P2(x) (so my new P(x) is just the pressure field from the first P(x)).
I then repeat the step again, with P2(x) being used for the velocity inlet equation and so forth.
The problem is the method of which I am doing this. I am currently solving the problem, then exporting the data to a text file and then re-importing that again as a new function. Is there any way to get COMSOL to do these iterations manually? I only ask because I need to run a couple hundred iterations each time.
Thanks in advance.
Keshava
Hello Keshava Murthy
