geometry toolbar-sweep function
Good morning.
I would like to create a 32 plies stack.
I have drawn the first block and than i've clicked on Sweep.
I don't find the box in which i can edit that i want 31 repetitions of the first block. I can only select the edge to be taken as reference (the depth of the first block), but i want to stack 31 more plies over the first one.
Also, using 4 times the sweep function in the geometry toolbar i can only stack 16 plies. Since the 17th layer the figure is completely changed.
So i would like to know if there is a way to edit that i want 31 repetitions of the first block in the Sweep function or if there is a maximum limit in the stacked blocks.
Thank you,
Alice
3 Replies Last Post 21.04.2016, 13:53 GMT-4
Posted: 10 years ago 21.04.2016, 12:24 GMT-4
Alice,
Attached is geometry of sweep with 31 repetitions.
Sergei
Alice, Attached is geometry of sweep with 31 repetitions. Regards, Sergei
Posted: 10 years ago 21.04.2016, 12:40 GMT-4
Thank you.
I have version 5.0 and an error window tells me that the model has been created with a latest version, so it cannot be opened.
Could you please send me the 5.0 version?
Thank you very much!
Alice
Thank you. I have version 5.0 and an error window tells me that the model has been created with a latest version, so it cannot be opened. Could you please send me the 5.0 version? Thank you very much! Alice
Posted: 10 years ago 21.04.2016, 13:53 GMT-4
Alice,
Attached is 4.4 version.
Sergei
Alice, Attached is 4.4 version. Regards, Sergei
