2D Cross Section and Parametric Sweep
Posted 24.05.2018, 11:43 MESZ General, Parameters, Variables, & Functions Version 5.3a 2 Replies
Dear all
I am simulating a Cross section of a 3D problem. Everything goes well, except when I want to sweep a geometrical parameter (with the Parametric Sweep, not Auxiliary of course.)
If I do it, it does not reconstruct the 3D object and then takes the linecut. All I have is a warning: "3D objects preceding work plane need rebuild." That is strange as I am pretty sure it worked in the past (5.3)
Is there is a way to force the 5.3a version to update the 3D before taking the Cross Section ?
This is a severe limitation to Cross section...
PS: It works by sweeping a material parameter, so the parametric sweep is working
